what I was shown
It's easy enough to find out it just involves a controlled environment with of course a heart rate monitor.
It's best to do it on your trainer at home as it keeps the variables to a minimum. You need to do it in stages such as 2 mph every 4 minutes or such. Consistency is key.
start with a warm up and when ready start the increases. Keep them up until you cannot anymore then cool down. You then need to get a piece of paper and your hr monitor and write down the rates as they appear on the watch. I guess I should have mentioned that you should set your watch for the smallest intervals it will record at.
Now what you will be looking for in those written down numbers is where the hr gradually increases and then gets temporarily stuck . Meaning where your hr doesn't increase consistently with the workload.
Example .... 155bpm -30mph, 160- 32mph, 169-34mph, 170bpm-36, 171-38mph, 177-40mph, 172-42 mph and so on. I guess a better way of putting it is that you should see a little flat spot.
I use this method for running on a tread mill and it works great. This combined with a true max hr test and your resting heart rate is a very good indicator of how your training is going.
I'm not sure if you have ever done a proper max hr test before but if not then your hr monitor isn't being used properly. The 220- your age is about as out to lunch as a random guess.
Type in "conconi" to your search engine and there will be more clarity.
Dallas "don't forget the max hr test" Sigurdur
and now that I think of it you could always use the "if you cannot hold a conversation your going to fast" method.
