Troll or bored?
http://forums.mtbr.com/showthread.php?t=477708
http://forums.mtbr.com/showthread.php?t=478557
Our conclusion was that the 09 is a better bike than both 05 and 08, most notably when climbing and under acceleration. It still feels very much like a Turner in every other respect and the frame is beautifully made,
This bike rides really well. My first impression is that it is an improvement from the original Sultan. I had no complaints about the original but was wanting a little more travel and the new suspension was an added bonus to me. I think the DW link works really well. It was very smooth when seated and pedaling in the rough flat areas. When climbing I felt a definate stiffness in the pedal stroke but the suspension was very complient (pedaling definately separate from the suspension action).
This frame is very stiff. I am not a superclyde but with my weight, (~225 lbs with bike costume) I did not notice any lateral frame flex what so ever. The linkage and rearend definately look more substantial when lookin down while riding.
I did not notice the added .7" of travel (compliment). I am certain it was working and was getting full travel out of my rear shock. In the rough downhill sections it worked great. Nice feel (I need to play with rebound) on both the shock and fork.
http://forums.mtbr.com/showthread.php?t=474010
2 Weeks Ago #11
JTBAZ
Posts: 724 I have owned Horst link and TNT Spots; and now I own a DW Spot. The Spot handles the rough stuff incredibly well. I have noticed rough sections of trail are smoother to ride through on my DW Spot. The suspension is smooth and plush. You can mash on the pedals and there is no noticeable or very little movement of the rear suspsension. It is incredibly stiff. It also maintains that classic Turner balanced feel. I would recommend it for the type of riding you described - you will not be disappointted.
http://forums.mtbr.com/showthread.php?t=474501
Copenhagen
Posts: 21 First impression
Alright, I spend +3 hrs on the new 09 Flux today. The bike is a freaking rocket. Turner has a hit here. The bike really impressed me on the climbs. Lots of traction both while seated and while standing. I was positively surprised by being able to clear steep rocky and root filled sections while standing. My old bike - a 2002 Trek Fuel (.. yeah, I know) never had traction out of the saddle in those areas.
Descending is awesome. The Flux is very confidence inspiring and comfortable. I felt, I could go downhill much faster that I used to and it didn't feel sketchy (credit to the tires too, I guess).
On the trails I rode it with propedal set to 1 and OFF, which seemed to work well. With rear sag set to ~30 percent the bike feels really soft when you initially sit on it but at the same time it pedals great and bob is not noticeable on the trail. The combination of the soft feel and the great pedaling is almost a little freaky the first time you experience it (I had the same experience on a Pivot Mach 5 that I demoed). I flipped the propedal ON (still in position 1) for a couple of section on pavement. That almost gave the rear a locked out feel so that worked well for the road and might work well for extended smooth climbs too.
Yeah, they suck and they are soooo expensive, I mean who the fokk would buy a full XT Turner for $4700 when you could have an imported frame and similar parts for the same price.
DT
edit!
Having come off of an Ibis Mojo, I can say that the number one difference in ride quality is without a shred of doubt, the STIFFNESS. An Uber Stiff rear end is a nice thing to have. I felt like I was on my Highline on some of the corners. Like riding on rails. Point and shoot. Even when subjected to the venerable parking lot- grab the tire , hold the saddle and pull- test the Spot passes with aplomb. Before I received my Spot Jarret at Turner told me that
this Spot was one of the stiffest frames thatTurner had ever produced. I figured he was hyping up the product. Turns out he was right on.
I ran the rp23 with about 35% (eyeballing) sag, and it seemed to keep up with the z1light just fine. I'm sure Push will be providing a nice upgrade to those who feel like they need it. I did bottom out the rear on couple of drops but I attribute that to poor rider style if anything.
Trail chatter was easily soaked up, it really feels like it has more than 5.5" of travel. I weigh 210 geared up, give or take a couple of burritos, and ran about 160 lbs of pressure in the large volume rp23 can.
On a section of trail that was downhill but littered with baseball sized mini baby heads, I purposely stayed seated just to feel the ride. The spot has a very smooth suspension path. It was so easy to just relax and let the bike do all the work.
I did notice on two occasions, a slight almost imperceptible pedal kick when climbing the rough in the granny gear. Not as pronounced as I've experienced on VPP bikes like the Intense 5.5 or 6.6, but still there. Not sure if its right to call it a pedal kick, maybe like a slight tug. Still, overall the ride quality matches the craftsmanship that Turner is famous for.
When climbing, the DW linkage shines. Really neat to look down and see very little movement, when you expect to see a whole lot of bobbing. This Spot is the perfect synergy of suspension design, frame craftsmanship, and fit. Add in the awesome Customer service and you;ve got a pretty cool thing going.
I think I'm gonna keep this one for a while. I may have to give up my Homer Poseur status this year.
http://www.mtbr.com/mfr/turner/allmtn-full-suspension/5spotdwlink/PRD_425923_1547crx.aspx
