1 - 20 of 28 Posts
Super Moderator
If you consider shop time at ~C$60/hour then IMO it's a bit high but not outrageous.
Wheels, brakes removed, fork has to be taken out from bike, washed, dried and cleaned with alcohol to remove 100% of grease. Time taken to apply wrap perfectly and then put everything back together.
and at the current market rate C$100 is about US$80
Discussion Starter · #8 ·
This is bran new fork from the box
Sent from my SM-G965W using Tapatalk
BOOM goes the dynamite!
"Wow, that clear tape you put on there looks great. How much is it?"
Shop employee crumples up work order and heads to cash register...
"That'll be...uhhh...a hundred dollars, sir."
for a fork, too much. for an entire frame, not enough. a tailored ridewrap kit is a PITA to install, if you are meticulous about it. i've done three now, and it's 4-5 hours if if i'm careful about it. maybe i'm slow.
1 - 20 of 28 Posts
