I guess that's my question: what's the Kula Deluxe chainline?Danke said:68mm is the right size, but what front chainline will that 113mm axle give with your crank? Should be 47.5mm.
Thanks, useful info. Already have a 752 crank so I've ordered a 113...top_ring said:I have (3) Kona framesets. Two 97`s and a 05. All are 68mm shells as are ALL Kona frames. BB spindle lengths depend on your crank arm offset. I can only recommend for a RaceFace Next. For the best chain line with this crank use a 107-108mm. If you`re using an older crankset such as Kooka, you`ll need a 116-118mm length.
Haggis said:I guess that's my question: what's the Kula Deluxe chainline?
113mm axle will give 47.5mm chainline with 752 crank according to Shimano PDF, so it should be ok.. Cheers.
