My Kendas have been getting a good workout the last few weeks. First our unusual snow blast in January, and then a good half-dozen slopfest rides since then, so I'm getting to know them pretty well. Some things are becoming very clear:
It's rides like today that remind me why I took the plunge and went 29". And the Klaw makes it possible.
- The rear Klaw is one of the best tires I've used for climbing in mud. The only one I've found that is better is the Hutchinson Alligator. Still, the Klaw is close, and it has wonderful predictability. It breaks loose gradually, so it's easy to modulate power on a steep slippery climb and stay on the bike. Heck, on some juicy climbs today I was running out of power before I ran out of grip.
- The front Klaw tracks fantastically well through thick deep mud. I suspect this may simply be a property of 29" tires in general. In Portland's Forest Park there are lots of stretches where you have to ride (sometimes steeply downhill) through a gooey mess of mud and decomposed leaves that is 4-6" deep and sometimes rutted. Even with great mud tires, my 26" bikes always felt sketchy and wandered around through these sections and I knew I had to be careful not to wipe out. With the Klaws I feel far more confident in this stuff, even at fairly high speeds or when I'm going steeply downhill.
- The 29"er tires property of rolling better over uneven terrain is also a boon on steep descents. Today's ride was peppered with branches and occasional small logs from recent storms strewn across the trail, and on a steep slippery descent it's nice not to have to interrupt braking as long (if at all) to ride over these little obstacles. One trail today finished off with a very steep 30-40' section on slick, slightly off-camber clay -- and with two 8-12 inch drops in the middle thrown in for good measure. On 26" tires there is no way I could have ridden that safely - even without the mud there's a moderate risk of going OTB. On the Klaws I did it with confidence to spare.
