1 - 7 of 7 Posts
· Registered
I just received a kindshock I900R 75/300mm. The problem is that it is too short out of the box. It is now 65 mm extended iso the required 75 mm.
I tried to pull on it, but it doesn't extend.
The other problem is that it is also a bit short for my frame, with the extra 1 cm that it should have, it would clear the minimum insertion mark in my frame and be only a bit over the minimum insertion mark of the post. If I am certain that it will extend a further 1 cm, I could install it on my bike and try to extend it like that.
But if it is still too short, I would have to sent it back and if it has been installed, that could cause problems. I weigh 75 kg and only ride XC/trail, so no jumps. So I would expect that the seat post would be able to hold this.
· Registered
Discussion Starter · #3 ·
The price is almost the same. 75 was enough for me and the weight was also a bit less, which was one of the main reasons I took this one.
Is it normal for this post, that it is impossible to lower the post by hand?
I have not installed it yet, but I tried to press the seat post down to see if it would come up completely afterwards, but I really cannot get the thing moving.
· Registered
The KS posts are a bit stiff when new/left unused for a while. If you run it a few times, the post will work smoothly.
As for it being too short, I'd get the 125mm version just in case you swap frames down the road.
· T.W.O.
Yes it's normal for KS to be harder to lower by hand, you got to lean into it. On the bike it's makes no difference.
· Registered
Discussion Starter · #7 ·
Just as a followup:
I sent the post back and received a 100/350 one now.
I just put it on my bike to see if it works, and after pulling the saddle up, there is completely no stiction. Now I have to change the red parts for the blue ones that I have and then I can really install and try it.
1 - 7 of 7 Posts
