1 - 5 of 5 Posts
· Registered
I found a 2022 Kona Woo in my size and wondering what suspension fork it was designed to work with. The shop is saying what they think "should" work but that won't mean anything if there is a warranty issue with the frame. Nothing on the Kona site for what they recommend. I believe the Mastodon 120 Ext is the ticket but hoping you can you can confirm that:
The A to C for the Woo is 530.
A Manitou Mastodon Ext 120mm A to C is 550mm.
Taking into consideration sag at 20 percent, .20 x 120mm=24mm.
550mm-24mm=526mm
That should be more than close enough. Right?
· Registered
550mm-24mm=526mm
I run a 100mm Bluto on my 2021 Kona Woo and have also run it with my 120mm Bluto. Both work fine, I like the 100mm better as it makes the bike snappier. Bluto works with both a Bud and Johnny 5
· Registered
Discussion Starter · #4 ·
Thanks guys. And good to hear about the 100mm Bluto. I am also considering the Wren 110 but wasn't sure about it since it's AC is 530 and with sag, 508mm. I thought the difference might be a bit too much. But if the 100 Bluto works, then the Wren should work as well.
1 - 5 of 5 Posts
