First, you're comparing two very very different bikes, they're not meant to fit the same way. One is not right or wrong, it's just about personal preference and optimizing that bike for your needs.
It depends on how much higher you're attempting to get? Yes, riser handlebars are the quickest/easiest way to get your hands up higher. A 30-40mm riser will be a significant change for instance.
If you're looking to get higher than that you may find that you start running out of cable/housing at some point, depending on how much cable slack you have to work with.
There are riser handlebars available with 50-100mm of rise too if you're looking to make a bigger jump? I wouldn't swap the fork unless you were making a change to a suspension fork or something, in which case Kona recommends a maximum fork length of 100mm for the Unit just FYI.
