1 - 20 of 45 Posts
SS Pusher Man
Prefer the swinging dropouts on the El Mar over the sliding dropouts on the Kona.
Other than that, get the one that fits the best.
Discussion Starter · #9 ·
Can you get Units as frame only? I was thinking I'd like to swap steel in for my AL HT frame too.
I don't think you can, but I might be able to sell off the parts or work a deal with the LBS. If I can't, then it makes the decision easier for sure, depending on how much I can get the El Mar frame for.
The Kona Honzo has a 68 degree headtube angle, probably a lot too slack for the twisty-turnies, but fun for aggressive downhill (as advertised). The Canfield Nimble 9 has a 70 deg HTA, better in my book, but still not 71. I've ridden bikes with slack HTA and found them hard to steer - maybe you'd get used to it (?).
Unit FTW
I have an '07 Unit 2-9 (the purple one). It's one of the best bikes I've owned. I think the shorter chain stays on the Unit would be much preferred over the Salsa. I bought mine as a frame and fork only. It was cheap. I've run it rigid and with a Fox F29 at 100mm and as a singlespeed and 2x9. It's a great, versatile bike.
I have an '09 Unit that bought (frame only) off of a forum. It's been a very good bike.
I had the slider/wheel/chain set one link longer than necessary when I first built the bike. Shortening the chain, and effectively the chainstay, made a noticeable improvement in handling. The Unit felt a little lazy and heavy with the longer wheelbase. Shortening the wheelbase made it somewhat easier to toss around and much easier to manual.
I've read of drive-side chainstay/seatstay failures on the Unit, but I've not had any issues. Also, I believe the geometry changed significantly in '10 or '11.
This thread needs some photos.
EXORCIZE
These were my final two choices. Got the '11 Unit new on e-bay for $319 shipped. I'm in very rocky terrain so the higher bb height was appreciated. And I prefer a shorter chainstay length (am running it SS). Never rode a Mariachi so I can't compare rides. Mariachi is pretty, but I also like the sleeper look.
aka "SirLurkAlot"
Tough to find right now but the Inbred is another option.
I've owned 8 HT 29ers and went back to the Inbred. However, I don't have experience on the Kona. I like the Salsa's dropouts but not enough to buy one at twice the price.
1 - 20 of 45 Posts
