kyle coxon said:
We've been having problems with R. derailleur breakage on both a Stinky & Stab, after some reasonable drops. We've gone thru a Deore ( bike was 1 week old), LX (bike was 3 weeks old) now an XTR on the Stab. Is there something wrong with our setup that would cause derailleur to extend & shift in so far to go into the spokes? The landings aren't unusally hard
I haven't seen anyone post this problem in a long time. My roommate had the same thing happen to him on a Stinky (2001.5). He would land a drop and suck the derrailler into the spokes wrecking the derrailler and the hanger and doing some damage to the wheel.
I don't think we every solved the problem, although I can tell you that it was not the chain length, since we mocked up a piece of wood in the compressed length of the shock and setup the chain with that.
We were kinda down to one of two things. The rear cable may have been getting hungup somewhere when the bike compressed a lot and when it extended it would pull the cable way passed where the shifter would. But a properly setup derrailler stop should have prevented this. We also had another scenario where the chain would whip up and on landing either pull the derrailler off the hanger or bind it up on the cassette so that when the cranks turned the derrailer would rip off and find the wheel. (I don't know if that is very clear).
This problem appearently happens, but it was kinda infrequent since he would land some drops without issue. He did go through 2 or 3 deraillers...
Good luck though. You may try searching the archives. I had the same user name, and I think his was traxxas.
