1 - 7 of 7 Posts
I am new to cycling and don't want to spend a ton of money (just in case I buy it and never pick it up again). My budget is about $400 but is somewhat flexible. I am okay with new or used, and LBS, eBay, Craigslist, etc. From going into LBS's I have been told I am a 19 or 20 (depending on the place. I am 25 years old, male, 6'3", wear a 34-35 inseam and weigh about 200 pounds. I plan to use it mostly for commuting, but want something that I can take off-road.
I was thinking about buying either the kona lana'i ($350) or the specialized hardrock ($399).
The Lana'i specs are:
Frame sizes 14", 16", 18", 20", 22"
Frame tubing Kona 7005 Aluminum Butted
Fork Suntour XCC-D 63mm
Headset Ritchey LB-Plus
Crankarms Suntour CW-XCC-T102
Chainrings 42/34/24
B/B CH
Pedals Xerama SP-941S
Chain KMC Z-72
Freewheel Shimano HG30 (11-32, 8spd)
F/D Shimano Tourney
R/D Shimano Altus
Shifters Shimano EZ-Fire Integrated
Handlebar Kona Riser
Stem Kona Control
Grips Kona Mooseknuckle
Brakes Tektro M530
Brake Levers Shimano EZ-Fire Integrated
Front hub Formula
Rear hub Formula
Spokes Stainless 14g
Tires Kenda K-922 26 x 1.95
Rims Rigida Cyber 10
Saddle WTB Speed V Sport SE
Seatpost Kona Thumb
Seat clamp Kona QR
Color Blue/White/Black
The hardrock specs are:
FRAME A1 Premium Aluminum, double-butted, ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable 98954020 alloy hanger
REAR SHOCK N/A
FORK SR Suntour SF7-XCM, 100mm travel, 12": 80mm, 30mm Hi-Ten stanchions and steerer, one piece alloy lower, coils spring mcu w/ preload adj., spring assisted seals, custom paint/graphic
HEADSET 1 1/8" threadless
STEM Specialized 3D forged alloy, two bolt, 25.4mm, 10 degree rise
HANDLEBARS Alloy 25.4mm, 640mm wide, 38mm rise, 8 degree back, 6 degree up sweep, 3.2mm thick
TAPE/GRIPS Specialized Enduro, dual density Kraton
FRONT BRAKE Pro Max, alloy "V" w/ linear spring
REAR BRAKE Pro Max, alloy "V" w/ linear spring
BRAKE LEVERS Shimano EF-50, integrated
FRONT DERAILLEUR Shimano Altus FD-M310-6, top swing, 34.9mm clamp
REAR DERAILLEUR Shimano Acera RD-M340
SHIFT LEVERS Shimano EF-50
CASSETTE FREEWHEEL Shimano HG-40, 8-speed, 11-32t
CHAIN KMC X8, 1/2" x 3/32" w/ reusable Missing Link
CRANKSET SR Suntour XCM-T312, replaceable rings, Octalink spline
CHAINRINGS 42S/32S/22S
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68 x 118mm for 50mm chainline
PEDALS Steel cage, composite body, 9/16"
RIMS Specialized/Alex HR 26, double wall w/ CNC
FRONT HUB Specialized, forged alloy, 32h, polished races, steel QR
REAR HUB Shimano FH-RM30L, cassette, 32h, QR
SPOKES 1.8mm (15g) stainless
FRONT TIRE Specialized Resolution, 26x2.1", 30TPI, wire bead
REAR TIRE Specialized Resolution, 26x2.1", 30TPI, wire bead
TUBES Specialized schraeder valve
SADDLE Specialized Aggro, kevlar sides, front and rear bumpers, 143mm width
SEAT POST Specialized alloy two bolt micro adjust head, 30.9mm
SEAT BINDER Specialized alloy w/ QR
NOTES Chain stay protector, reflectors, clear coat, owners manual
I also found a dew deluxe on ebay with a dart shox 1. The seller claims it is a 2008, but I think, from looking at konaworld, that it is a 2007. I would be paying $381 plus shipping if I did this.http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=200234687682
The discription is: Special edition Kona Brewing Kona Hahanna Cross-Country Mountain Bike, Forest Green, 24 gears, disc brakes, Dart Shox 1, Aluminum 7005 frame, 19". It seems to me that this is basically a roadbike with mountain bike components.
The Dew Deluxe specs are:
Frame sizes C49cm, C52cm, C54cm, C56cm, C58cm, C60cm
Frame tubing Kona 7005 Butted Aluminum
Fork Kona P2 700c disc
Braze-on fittings 2 bottles, fenders, rear rack
Headset TH
Crankarms FSA Alpha Drive
Chainrings 48/36/26
B/B RPM 7420ST
Pedals Wellgo LU-A9 w/ Toe clips and straps
Chain Shimano CN-HG50
Freewheel Shimano CS-HG40 ( 8-SPD, 11-34T)
F/D Shimano Acera-X
R/D Shimano Deore
Shifters Shimano Rapidfire
Stem Kona Control
Grips Kona Jackshit
Brakes Hayes MX4 Mechanical
Brake Levers Avid FR-5
Front hub KK Disc
Rear hub Shimano FH-M475 disc
Spokes 15g front and 14g rear stainless DT
Tires Continental Country RIDE 700x37c
Rims Sun MZ 14
Saddle WTB PURE V SPORT
Seatpost Kona Thumb
Seat clamp Kona QT
Color Grey
Either that, or at that point, should I just get a fire mountain? It would be more than I want to spend (I want to spend about $400 but this would be $500 + tax).
the specs for the fire mountain are:
Frame sizes 14", 16", 18", 19", 20", 22"
Fork Rock Shocks Dart 1 100mm
Braze-on fittings 2 bottles, fender, disc tabs
Headset TH
Crankarms Suntour CW-XCC150PB
Chainrings 42/34/24
B/B TH M-1
Pedals Wellgo LU-C3
Chain Shimano IG-70
Freewheel SHIMANO HG-30 (11-32t, 8speed)
F/D Shimano Tourney
R/D Shimano Acera-x
Shifters Shimano Alivio
Stem Kona Control
Front hub KK Disc
Tires CST Crusader 26x1.9
Rims ALEX ACE-18
Seatpost Kona Thumb
Seat clamp Kona QR
Color Grey
Your help is really appreciated and thanks.
Discussion Starter · #2 ·
Also, I am located in Las Vegas
If anyone knows of a place that sales used bikes here I would appreciate it, or a place that has a decent selection online. I have googled extensively but have yet to find a good result for either.
ride hard take risks
Welcome to the forums. :band:
Craigslist is usually a good place to look for used but if you dont know what your looking at you can get ripped off pretty quick. :cool:
At your height 19-20 or LG sounds like a good fit. :)
Great bike for the price check out the Alpine 650 at $669
http://www.ibexbikes.com/Bikes/ALP-650-Details.html
or the 450 at $469
http://www.ibexbikes.com/Bikes/ALP-450-Details.html
both with disc brakes and excellent customer service. :rockon:
I adore my Dew Deluxe, she's a killer urban assault bike, and perfect commuter. I'd probably upgrade the wheels and get some cross tires before I'd do any serious trail riding on it though.
I plan on getting another Mountain Bike in the next few months for the trail though.If you plan on doing mostly trail riding, I'd go Fire Mountain or maybe a Blast. I just don't care for knobbies and a suspension fork on pavement. They kind of work against you. Specialized makes nice bikes, I just really like Kona's fit and bang for the buck.
EDIT** the ebay link isn't a dew.
the 2008 dew has hydraulic disks and is gold, sorry, got ahead of myself**
Discussion Starter · #7 ·
thanks for the help. I was kind of leaning towards kona and you really helped sell me on it. It seems like kona is the same or a little better for comparable bikes at a little less price than specialized.
1 - 7 of 7 Posts
