I have a 2008 Hei Hei 29er with the RP3 and the Reba. I swapped out the wheelset right away for a Mike Curiak-built set with Hope Pro II hubs and Bontrager Mustang rims. I also converted the Reba to 100mm. Otherwise the bike is stock. It is around 28 pounds with Eggbeater SL's and a cheap bottle cage.
I like the Hei Hei as a trail bike. It is very stable going up and down. It is built like a tank; I think I've plowed through every rock field from Portland, OR to Moab, UT and it doesn't seem any the worse for wear.
One problem; if I don't keep the chain lubed, I get some pretty bad chainsuck. Happened on the first ride and I notice it every time I forget to lube pre-ride. Not a deal-breaker, but worth noting.
I've not raced this bike, and I don't think I ever will. It is a bit heavy and it would cost a good bit of coin to make it light. However, it is a great all-day bike that performs better as the trail get rougher.
Feel free to PM me if you have questions.
Joe
Joe
