I am selling my size Large 2019 Knolly Fugitive LT 29er. This bike was built as a custom build in October 2019. This is a fantastic front range trail bike with 135mm rear travel, 150mm front travel, and modern geometry. It features adjustable geometry, and can be run in neutral (66 Degree HT angle) or slack (65.25 HTA). It has a nice steep seat tube angle and 430.5mm chain stays which provide a good balance of stability and maneuverability while descending. The bike is a quick climber, and especially good climbing the technical climbs we have on the front range. These bikes are not the lightest, but they hide their weight really well. The frame material is 6061 raw alloy, features dual-row angular bearing in the pivots, titanium hardware, and is easy to keep clean and bulletproof. This frame also has an All Mountain Style downtube protector and fork tube protectors. There are no cracks or issues, all bearing running smooth. There are signs of use, but the frame is in excellent condition. The rest of the components have small imperfections from use, but everything is in working order. The cassette, chain, and bottom bracket were replaced less than 100hrs ago. Fork had a complete damper overhaul, lower service, and new seals less than 50hr's ago. Rear shocks were both serviced this spring with new seals and have less than 50hr's per shock since service. Brake pads are 75% both ends. Bike just had a basic tune, new chain ring, and brake bleed prior to sale. Wheels are tight and true with no dents. This bike is a custom build with the below components, and comes with two air shocks for difference amounts of suspension travel. With the 120mm Fox, the bike is more nimble and more playful, and with the 135mm Rockshox, you get a little more plush ride more suitable for steeper and rockier terrain. It was truly a pleasure to own this beast, and it will be missed.
-Fox Float 36 Performance Elite Fit4 150mm
-Fox DPS Factory shock 185x50 (120mm travel)
-Rockshox Super Deluxe Ultimate shock 180x55 (135mm travel)
-SRAM Code R Brakes -200mm front rotor, 180mm rear rotor
-SRAM GX Eagle Shifter
-SRAM GX Eagle Derailleur
-SRAM GX Cranks (170mm 32t chain ring)
-SRAM DUB BB -Cane Creek 40 headset
-Wolftooth finishing kit -E*Thirteen Helix R Cassette (9-50 345g)
-Ibis 938 Wheel Set 35mm
-Maxxis Assegai 29x2.5 front (60% thread)
-Maxxis Aggressor 29x2.5 rear (95% thread)
-Cushcore Pro in the rear wheel
-Ride Alpha 780mm alloy handlebar
-Synace 40mm stem alloy
-SDG lock on Grips
-Brand-X 170mm dropper post
-Specialized Dropper Lever
-Specialized Henge Comp Saddle
-Fender
Does not come with pedals
I'm asking $3,200 OBO. I will entertain reasonable offers. Shipping available at buyers expense within the continental US.
Located in Denver Colorado.
-SDG lock on Grips
-Fender
