I'm wondering what the typical amount of knocking is on these forks? I picked up a used 2012 Fox 40 RSC2 during the off season. I put in a softer spring after getting it and it seems the knocking got louder. Things I've checked/done:
Lowers service
Removed spring and plunger assembly cleaned and regreased and reinstalled. Yes. The shrinkwrap is still in place about a third of the way up the spring.
Cleaned spacers.
Double checked all torque specs.
And it is still knocking louder than I remembered. But maybe I'm crazy.
While I had it apart I checked the diagram https://www.ridefox.com/fox_tech_center/owners_manuals/07/eng/forks/40/40.htmp. All the parts are there and in good working order. No signs of wear/damage. I did notice, that unlike the 2014 model there is no part of the plunger that extends up into the coil and there is a bit of space between the flange and the inside of uppers so I'm not surprised there is play that would knock against the stanchion.
Anyway is knocking pretty typical in a 2012 40? Is it a problem? Did the redesign of the plunger shaft in 2014 quiet it down? Any reason to update the coil plunger assembly?
Lowers service
Cleaned spacers.
