1 - 4 of 4 Posts
· Registered
I just changed the seals on my solo air now when the fork tops there is a clunk and it feels like there is a little play. Maybe a couple of mils. I took out the bolts and reinstlled them, with no luck. The rebound side is leaking out the bottom a bit. I may need a new crush washer. Has anyone else experianced this "looseness" at top out.
· Registered
So all you did was remove foot nuts, remove the lowers, replace seals and reinstall the lowers ( with lube)???
Did you open the damper? The damper could be a little low on oil, or the rebound piston could be loose on the damper shaft....hard to discern with you description....
1 - 4 of 4 Posts
