1 - 9 of 9 Posts
I'd like to run my slider in the far forward position, but in order to accomplish this I'll need a 1/2 link.
I ordered a KMC 1/8" half link and it is ~.030 wider than the PC-1 (at the outer plates and the inner plates).
Is this OK? Or is there a better half link for the PC-1?
Thanks,
I agree w/ Tone No Balone - re: SRAM PC-58...
...In fact, I run the SRAM PC-58 w/ a KMC half-link on my Cove Hummer, w/ ENO eccentric hub in forward position. No problems. I've never really bought into the "PC-1" hype that SRAM promoted in its "singlespeed" chain. Try the PC-58...it's cheap and plenty durable, IMHO. Good luck!
Discussion Starter · #6 ·
So, Sram 8 spd. I'll have to give that a try.
I noticed that Sram re-did there part numbers, is the PC-58 now the PC 850?
Also, what is the difference between the Sram 8 speed chains (PC-830, 850, 870, 890)? Their website kinda blows for info...
Harris Cyclery website (RIP Sheldon) says...
http://harriscyclery.net/itemdetails.cfm?id=722
SRAM/Sachs
PC-58 Chain--Replaced by the PC-870 (CH1030)
$21.95
Product Rating
(0 Reviews)
Write a Review
The chain formerly known as PC-58, has been re-numbered:
PC-870.
SRAM has re-done their model numbering system, replacing all of the two digit model numbers with 3 digit ones.​
Soooooo, that said, I think you should try and grab hold of the PC-870 if you cannot find any new old stock PC-58 at your LBS. I usually buy a half-dozen chains in the springtime, which typically holds me over for most of a year - sometimes more.
That's a little off topic from the original posting on the half-link, perhaps. I think that KMC has a killer little half-linky link - and I use 'em frequently.
Hope this helps! Happy New Year.
1 - 9 of 9 Posts
