1 - 15 of 15 Posts
King Pin
Did an exhaustive search to no avail.....
Is there a CURE concerning the Reba's bits hitting the KM downtube?? Just installed a new Reba, and have bumped the DT twice now, before the first ride!
Running a simple "Aheadset" headset.
Powered by ice cream.
If you get a King headset, I can set you up with a lower Race made by Ventana that will allow you to clear it.
Good excuse to upgrade.:)
Or get a Cane Creek S3 Plus headset...the lower cup is 5mm longer. I actually might have one of those in the garage as well (the lower cup) if you have a Cane Creek HS you can install. Only comes in black. Don't know if it is compatible with the Aheadset.
You went squish? What's next freewheels and gears?
King Pin
Discussion Starter · #3 · (Edited)
I was hoping you'd chime in Eric!
I have a King HS that can be pulled from the Vulture, that and the Ventana race will allow the necessary clearance??? Ed and I installed the sproinger today, and I didn't think there would be any major problems, but the downtube on the KM is already getting dinged up....and I haven't even ridden the bike yet! Damn.
Running 150/150 lbs currently, seems TOO squishy, although no bottoming out.....guess LESS negative air?
I have several ENO freewheels, and do tend to use 'em on occasion.....gears??? blahhhh....never again.
Jr.M said:
Hey folks!
Do you have any idea where to get those Ventana races in Europe? Or do I really have to order overseas.. :madman:
Cheers.
Jr. M I have a +7 Ventana race, PM me if you want it ( I didnt pay for it so all I would ask is you cover a few $$ for shipping)
There is also the ******* solution (what I did). Cut a couple inches of 1 1/2 inch ABS (or PVC) pipe, and carve it out so that it fits nicely around the fork tube and shields the lock/damper from the frame. A couple cable ties has held mine in place for well over a year now, and it has withstood many crashes.
It's not pretty, but it works.
1 - 15 of 15 Posts
