Just got a new bike that came spec'd with the 2004 Shimano XT Hydro disc brakes. My first Disc and Hydraulic brakes. The length of the rear brake cable is just right and like to point out that the LBS mechanic, who build it up, is a very knowledgeable and experience wrench. The cable routings are setup properly.
On my 2nd month of riding the bike, the rear brake line developed a kink next to the frame's rear suspension pivots from the bike's constant suspension movement/travel. (Santa Cruz Blur - rear brake line runs thru the side of the top tube and continues to the seatstay to the rear calipers.)
The Hydro cables are stock that Shimano includes with the XT Disc brakes set. Just wondering if this constant bending/movement of the cable will wear out the brake cable's integrity in the long run, possibly causing a leak.
Should I order a new set of cables now? Anybody recommend a more durable Hydro cable that will fit the Shimano XT?
