1 - 7 of 7 Posts
Hi
Just got a Fox RP3 shock to replace my Rock Shox. The bushing are different in size. Any suggestion on where to get new bushings to make this thing work? Thanks
You can call Fox directly, that's what I did. My 2008 frame uses the sizes below which were confirmed by Bob's bicycles (where i bought the frame).
I believe the number is 1-800-FOX-SHOX..
Upper mount width - 22.2 mm
Lower mount width - 36 mm
Discussion Starter · #4 ·
I have a micrometer so yes I do have the proper measuring tools. Those are the exact numbers I got RSab, so I will call FOX on Monday. Thanks for the headsup...My frame is also a 2008
1 - 7 of 7 Posts
