1 - 10 of 10 Posts
27
thebronze said:
I thought it was 27.2 but I cant cram it in.
Anybody know the right size?
26.8 or 27.0 ?
When I first got my solo-one (an '05) I pulled the seat post out to check it and 27 was stamped at the base. I can double check it when I get home tonight.
Bigger than Big
thebronze said:
thank you, never seen a 27.0 before, its always been 26.8 or 27.2 .....
Maybe its the true temper tubing.
My 2001 ST (all-steel) is a 26.8.
i think mines a 27.2... maybe the post is actually a 27 and the tube is a 27.2 because the (stock) post just freefalls down the tube unless i clamp it down a little bit
anyways the tubing is Reynolds , not TT
I'll check it again tonight and post again. I will also measure with some calipers. I know Thomson sells a 27 version of their post, so there must be some applications for it.
A hopped on pop.
26.8 or 27.0 ?
hey toby....who let ya in here??? :D
ahhh....building a ss....SWEET!!! good luck on the build. at your size, you should be on a 29er. check your email.
cheers!
1 - 10 of 10 Posts
