1 - 12 of 12 Posts
Im in the market for a dirtjump frame and had two questions
1.)squishy or hardtail?
2.)is the khs dirtjumper/azonic stealhead any good?
i have a khs dj100 frame and i have no complaints other than the rear is a bit long and the v-brake mounts need to be removable.and a hardtail is better for dirt jumping and hitting the skatepark.
Meh.
Azonic STEELhead is much better. Now that I've said that, you're going to go buy the KHS.
The Steelhead uses better stock than the KHS, but I'm not sure I believe Azonic when they say it's a full 4130 cromo frame. It feels too heavy. Geometry for the Steelhead is also optimized for dirtjumping/urban. If you run discs, it can be tricky since the disc mount only works if you run the axle in exactly the right position in the dropouts.
You may want to look at the Giant STP. It is aluminum, but the geometry is totally dialed. And it's dirt cheap for what it is.
I've already covered the dual suspension issue.
Portland, OR
the steelhead are okay, they are usually really cheap. so you can go check one of those out. but I would reccomend looking around for a good used alu frame. stp, P. series, kona clump series hardtails. I've found the older P. frames to be pretty versatile, stp's are suppost to be really sick bikes. kona ... get one if you're planning on doing a little more dirt riding than park/street. or get the XS frame.
whats your budget ?
Discussion Starter · #5 ·
eh i dont need a dirtjump frame any more got meself a great deal on a devinci guzzler freeride bike so yah besides there is nowhere here to dirtjump but there is lots of places rarin for streetjump/freeride
Meh.
whats your budget ?
Thank you for phrasing that the way you did.
Potini'vegotastickupmyass. Shut up. If you don't want help. Don't post up. Or put me on the ignore list. In both threads I did provide information. I didn't say your frame was going to explode from sitting on it. You're the one that's unskillfully manipulating my words to try and make me look like a jackass. So shut the hell up.
Discussion Starter · #9 ·
lolz please move your arguments over to the "shock strength" thread so you dont bug these good people who offered alot of information to me
once again thanx everyone except mr. angermanagement over there
1 - 12 of 12 Posts
