wire bead or folding bead?
which has stronger sidewalls, I'm guessing the wire bead?
I've only used the wire bead version, 2.5 DH is double ply and burly and the 2.3 version is single ply and a little thin. No problems yet with the 2.3s, but they roll a little at lower pressures. The 2.5 Nevie Tomacs are my gold standard for Whistler and the Shore.CanadianPreston said:wire bead or folding bead?
I run my 2.5s 25-30 psi for everything except Whistler and for that I go to 35 psi, no problems and I weigh 235 with no gear. The 2.3s I run 30-35 psi depending on conditions. How low do you want to run them?skatetokil said:I really don't like the way these tires have to be run so hard to avoid flats. When things dry out here I think I'm gonna go back to maxxis.
