1 - 5 of 5 Posts
So my tubes keep popping on my mtb. I clean out the tire and rim and look for stuff everytime. The wheels on my bike are just stock and i know are pretty shitty, but i don't know if they are flexing or something super hard under pressure. i will hit drops and jump up to like 6 stairs so i don't ride it too hard i think. One thing i saw is where the rim meets the other side (the seam) its a little sharp, like its gone out of alignment from going out of true every time i land hard. I've tried to sand/smooth it out a little but idk if thats what cuasing my tube to pop every few times i ride.
Would it be bad to put a little piece of tape or something over the seam to protect it a little? Or are there any other tricks to keeping tubes form popping all the time.
local trails rider
If you run your tires too soft, the inner tube may get pinched between a sharpish obstacle and the rim: "snake bite".
More pressure and care over any obstacles with an edge should help with that.
No good in rock gardens..
Check your rim strips - if they have moved aside and expose the spoke holes, the holes can cut your tubes. The location, size and type of hole is a clue - one or two long holes like cuts could be pinch flats. One cut like hole on the inside of the tube when it seats on the rim might indicate the spoke holes doing it.
1 - 5 of 5 Posts
