I just installed my Fox F100x and now my 180mm Magura Marta SL rotor is rubbing the caliper.
I have the Magura IS-IS bracket, marked as Adapter 16 clearly on it. I had the fork mount faced by my LBS just so the bracket wouldn't hit the rotor itself. Now the rotor is hitting the caliper.
The part of the caliper that is being hit is at the far most edge of the rotor. Basically if the rotor was 176-178mm it would fit perfectly, but because it's 180mm it is "too long". Other than installing a 160mm rotor what is the solution here?
All parts are Magura so there isn't any incompatiblity here. Is it the location of the IS mount on the Fox fork? Could that not be long enough? Has anyone else fun into this before?
Thanks.
Thanks.
