too early to post a permanent review, but initial impression is that it's just about perfect for DJ
burly as hell, its 32mm stanchions are much stiffer than the 30mm on the 02 Psylo SL w/Tullio it is replacing
designed for the rider who wants to keep things simple: no preload (air or spring), rebound that makes a difference, 80mm (or 100mm - pick one), hexlock thru axle
feels like the rebound setting also adjusts compression damping
I weigh 170+ w/o gear and ride a '04 P.2. Got the 06 Manitou Gold Label Series 2 in 80mm. So far, the stock springs (I believe there are two) are just right for jumping, but just a bit harsh for trail. They're light enough to not get in the way of bunnyhopping, etc.
More later, after they're broken in.
