Not my rig but built at LBS (and posted on another internet site) Industry Nine DH/FR wheelset in PINK.
mmmm... now that is an idea...chad1433 said:Those are nice...My wife says "uh unh":sad: She's the one who bought the other pink stuff, believe it or not.
I've been thinking though...pink saddle...The Orange Peel bike shop here in Steamboat has two...stay tuned.
Stiffer in transferring rotational power sure, but what about lateral stiffness? I can't imagine these aluminum spokes will be as stiff as a steel spoke. It would have to be like 3 times the diameter, and am I correct in saying these are roughly 2 times?ahimanic said:The straight-pull spoke design is superior to the bent-elbow spokes--less breakages and makes stiffer wheels..
It is laterally stiff as well. Without the elbow in the spoke there is less lateral flex in the spoke. The spoke is pretty thick but not sure if it's 3X as thick as steel. I believe there are 2 versions--regular and lighter weight. I don't know which one the above pictures are showing. Aluminum can be stiffer and lighter than steel depending on the design (i.e. alum vs steel frame tubes) The large flange hub also lend itself to more rigidity (shorter spokes). You gotta see these wheels in person, I think you'll be impressed.UP Dude said:Stiffer in transferring rotational power sure, but what about lateral stiffness? I can't imagine these aluminum spokes will be as stiff as a steel spoke. It would have to be like 3 times the diameter, and am I correct in saying these are roughly 2 times?
I am anxious to see them at interbike this fall. Missed them last year.
I know I'll be impressed. They are amazing looking wheels. I just place a high value on wheel stiffness. I ride Spinergys, and I didn't know what I was missing until I tried them. It was comprable to when I made the move to a 20mm axle. The PBO fiber that makes up their spokes is much, much stiffer than steel. I think I would have a hard time giving that up, even to go back to a steel spoked wheel. One thing I do with they had was the engagement of the I9s. 3 degrees is pretty darn fast. I'm looking forward to viewing and playing with a set this fall in Vegas.ahimanic said:It is laterally stiff as well. Without the elbow in the spoke there is less lateral flex in the spoke. The spoke is pretty thick but not sure if it's 3X as thick as steel. I believe there are 2 versions--regular and lighter weight. I don't know which one the above pictures are showing. Aluminum can be stiffer and lighter than steel depending on the design (i.e. alum vs steel frame tubes) The large flange hub also lend itself to more rigidity (shorter spokes). You gotta see these wheels in person, I think you'll be impressed.
