Running tubeless really isn't about saving weight. There are really 2 main benefits.
- Less likely to get punctures and usually easy to fix if you do...often by simply pumping up again.
- Able to run a lower pressures without the risk of pinch flats. And lower pressures result in significantly better grip.
