Ok, so I just shortened up my rear hose for my Juicy 7's which was surprisingly easy (except for getting that hosebarb in). Per the instructions, I just cut the hose, replaced the barb and fitting and tightened it all back into the lever. Now I THOUGHT that I then had to rebleed the whole system, but figured I'd ride it and see how it worked. Just doing a quick spin around the block braking hard every 20', the brake seemed perfect! Is that right?! If so, I'm thrilled. I was dreading doing this figuting I'd f' it all up and end up crying all the way to the LBS! S
