I'm in the of installing some XT's disc brake levers and calipers.
The fork is FOX F100, the rotor is a AVID 160mm.
I noticed the Avid caliper had 2 sets of spacers on the IS bolt for mounting. The Avid bolts are longer than the supplied XT's one.
Do I need the special shimano adpater or will the one that I was using for the Avids work?
The XT's won't mount up directly to the IS post, the caliper body hits the mount.
I can use a spacer with the Avid mount but how much caliper needs to grab the disc, the more spacers I use, I imagine the less disc I'm grabbing.
