I just replaced by front brake pads because of a noise issue. When I went to dial in the pads I noticed the rubbing was not from pad-on-rotor contact but from rotor-on-bracket contact.
A little hard to explain, but the outside of the rotor is lightly rubbing on the bracket used to mount the Juicy 7 calipers. I can't even fit a piece of paper between the rotor and the bracket.
I've rechecked my wheel alignment in the fork several times and it appears good.
Has anyone ever seen this? What can be done? What happened?
