Note the sig. Selling my Mags.kidwoo said:Juicy.
Caminos fade in dh type riding
There's nothing wrong with hayes mags, never has been.
juicy's are where it's at.XSL_WiLL said:Note the sig. Selling my Mags.
Dam Stright!!!! Getting Rid of My Hayes, and getting Avid 7's. No Stopping power, will start a ride with kick ass feal, will get to the bottom and they feel like Sh!T.sriracha said:juicy's are where it's at.
elcaminos are juicy lookalikes not performalikes..
You should get the air out of them and quit dragging them so much.#1ORBUST said:Dam Stright!!!! Getting Rid of My Hayes, and getting Avid 7's. No Stopping power, will start a ride with kick ass feal, will get to the bottom and they feel like Sh!T.
Well Duh!!! Tell me your bleed prod. I do it step by step out of the book with my Mech. buddy, works great for awhile but when the caliper auto adjus. and opens up extra space in the caliper this causes it to be filled with the fluid in the line. Witch causes a bubble witch then I have to do it all over again.kidwoo said:You should get the air out of them and quit dragging them so much.
but why?? those brakes are greatXSL_WiLL said:Note the sig. Selling my Mags.
You don't seem to understand how hayes brakes work. There's a reservoir in them just like every other brake. They have a bladder that surrounds the piston that does the exact same thing as the reservoir in avids, shimanos or any other brakes for that matter. You know that little hole on the outside of the lever body? That's for expansion/contraction of that reservoir. It's a breath hole for the chamber surrounding the reservoir.#1ORBUST said:Well Duh!!! Tell me your bleed prod. I do it step by step out of the book with my Mech. buddy, works great for awhile but when the caliper auto adjus. and opens up extra space in the caliper this causes it to be filled with the fluid in the line. Witch causes a bubble witch then I have to do it all over again.
Avid has a res. so you don't have to worry and that.
And don't worry about my breaking it's all under control!!
Post them in the classifieds.XSL_WiLL said:Note the sig. Selling my Mags.
I don't know if I would go that far.#1ORBUST said:It has to be something with the fluid amt. We do everything you just said. Then when we put the wheel on and adj the break Contact. And the pads adj. The power just goes away. Any Sol???
I have had them prof. done and really it works great for awhile (Two rides) but then same thing.
Thanks for the info!!! Will tell my mech. buddy he is a loser!!!
I bet anything it was a pinhole. It's really only my rear that dose it. This weekend on shuttle up something clipped the line and tore it off the lever. Am replaceing the line tonight see if it will fix. (I bet when they put the hose to the lever the seal was not good.)kidwoo said:I don't know if I would go that far.
You might have a pinhole in the line somewhere. I've had something similar happen before. It may not leak but it might be letting air in to the crucial part of the system.....the hose itself.
If you have a good few rides after bleeding them and THEN they start to feel weak, it sounds like there's a hole somewhere. I replace the line first and see what that does.
I've had fluid leak from around the piston seals too but that was pretty obvious because fluid was getting on my rotors. Those things aren't that complicated so there are only a few things that can really go wrong with them.
