I put a thin layer of grease on the concave washers. Then, while the bolts are loose, rotate the wheel, stop it with the brakes and hold the lever. Tighten the bolts (alternate between the two as you tighten). I always tighten with a torque wrench to proper torque.
If you are still rubbing, look and see which pad is rubbing and stick a business card between that pad and the rotor, and repeat the process.
If that doesn't work, it could be that the gap between the pads is simply too narrow (pulled the brake lever without the rotor on, perhaps during shipping). Gently push the pistons back and repeat the first procedure.
