1 - 6 of 6 Posts
The lever pivot pin on my juicy 3's keep coming out. The pin does not have a clamp or anything on the side to keep it in so I'm not sure how they are supposed to stay in.
Any suggestions?
wannabe corporate shill
Look inside the lever there may be a hole where a screw would tighten up against the pin. It is likely tightened by a Torx or hex wrench.
GMCTT seems to be on the right track. It appears to sit above the reach adjuster. The instructions aren't clear, but step 32 on page 18 indicates that there is a "pivot pin set screw" to hold, not surprisingly, the pivot pin in place: http://www.sram.com/_media/pdf/avid/dealers/TM_MY09_E.pdf
It's interesting that there is no reference to this earlier in the instructions when they tell you how to pull the lever off.
Tim
1 - 6 of 6 Posts
