I have just gotten 3 super slow leaks in the tube under the Juggernaut Pro 26x4 tires. I like ride in the grass that is covered with sapling cottonwood trees that are alive and cut last year with field mower. When I run over the live and dead saplings that are cut off at about an inch or two from the ground it makes a nice snapping/rubber twang. I need to order some sealant resolve the slow leaks.
My question is:
If I go tubeless with the thin Juggernaut Pro will the sharp saplings cause more damage than if I leave the tune in it? I assume the tube is giving the tire more structure and that is what is preventing the twig from going all the way through the tire right now. I have the tires aired up 25 to 30 psi as I am riding on gravel, blacktop and grass right now and don’t need the added traction of low pressure. I assume if I lowered the pressure the twigs would be less likely to poke holes but I like riding on rock hard tires when I can.
I won’t be going tubeless until I get home this fall and will probably need new tires by then anyways but would still like to know if the Juggernaut Pro’s could hold up tubeless to sharp twigs sticking out the ground.
Thanks from Western Alaska
My question is:
