Hi guys, I'm at a dead end here and I was hoping someone can help me out. After countless hours of scouring the forum and web about which adjustable seatpost is good, I realized I may not even be able to use one to it's fullest purpose.
I don't know if my bikes is too big or if it's the design or if my legs are extra short, but my ideal maximum seat height is not all that higher off the seat tube. The bike fits me well, I think, and there's no changing that at the moment but I only have about 170mm from the top of the SP clamp to the seat rail(center of sr clamp).
I realized this morning that it seems most of the adj posts will be much higher then that with the full extension and lower tube clamped all the way down into the frames seat tube. Judging by pictures, it seems the Joplin has what seems to be the lowest possible height with the on the fly adjustable post extended to the max height.
Does anybody have any experience or suggestions for a situation like this? I understand I could still use it by lowering it just a little bit after full extension but thats a bit of a PITA and not ideal IMO. If someone knows how long it is from the seat rail to the top of the seat post clamp while the lower tube is in the frame all the way with the Joplin extended, I would really appreciate it.
Thanks a lot guys, I really appreciate it!
(tape measure is a little further away so it doesn't show a true 170mm in the pic)
I've looked at every other brand of adj seatposts and it seems they need a lot more length than the Joplin. Am I off on this?
