1 - 1 of 1 Posts
Jones LWB. Small frame (sizes run big, so if you ride a medium on any other manufacturer's size chart, you'll fit on this. I am 5'8" (~173cm) with long legs and fits me great. This is the 2nd gen Jones frame, not the 3rd gen, which is much heavier and more eBike-centric, and not the 1st which had QR dropouts and fork. This is a very durable, steel, thru-axle frame. Note, photos are older and some components may not match the ad, the ad copy is accurate. Also, I travel for work occasionally and may not be able to consummate a deal until the next weekend.
Here are the dirty deets:
Cockpit:
Jones H bar, 660mm/45degree, with brand new The Shadow Conspiracy grips.
Brakes:
  • SRAM Level calipers and levers
  • 203/180mm rotors F/R. Tektro
Drivetrain
  • NX derailleur/shifter, and 12 speed 11-50t cassette
  • Truvativ Descendant 170mm crank
  • Beat up VP components pedals if you want them
Wheels/Tires:
  • Jones Spec 29" wheels/hubs
  • Maxxis Minion DHF 29x3.0 tires
Saddle:
  • Probably will swap out the Fiz'ik Ardea saddle with the stock Jones saddle
  • PNW Components 100mm dropper with Loam lever -OR- I have the non-dropper post I can throw on there.
Ask if I missed anything!
Bicycle Sky Wheel Tire Bicycles--Equipment and supplies
Bicycle Wheel Tire Bicycles--Equipment and supplies Crankset
1 - 1 of 1 Posts
