1 - 18 of 18 Posts
UPDATE: It's installed. Jet 9 link test...
I have a pair of these coming from a shop I use to try on Thursday for a race Saturday. We designed these on our own in SolidWorks, did an FEA and think they will do until the revised Niner pieces arrive. I think Niner is doing a great job on the revision.
those look great and I like that you kept the original curved ends. what is the weight difference?
Superflying on Haven
I think these look even stronger than the new Niner design:thumbsup: . You could get some money selling them...Do you take special order :D
Padre said:
Pretty sure you are wrong on that. If I'm not mistaken it was the heat treatment of the metal.
I thought it was the Schlemberger process when applied to the Werth joint. I'm pretty sure the failure occurred as a result of microplasms forming in the octerior membrane of the alloy that they used.
Pretty sure that was it, no?
Discussion Starter · #9 ·
After I fit the first set off the CNC I'll know if the drawings were perfect. If that goes well, I'll offer them up but I imagine the pricing won't be great. These aren't straight hunks of billet cut on a band saw and then taken to a mill/drill press. Not to mention all the time into SolidWorks, but it's all for fun I guess. I can understand why Niner wouldn't want to just cut a big pile of chips and send us these in the mean time since it's a good amount of money to make these on the CNC. I suppose if we were running a big pile of them the costing picture would change, but no one needs a pile of these right now.
Discussion Starter · #10 ·
Here's the finished piece...
We didn't fully machine out the rear relief area. The FEA said OK, but for a few grams who cares. Rode it this morning. Dialed!
Feet back and spread 'em!
were they cracking? if so where? how is yours improved from the original? was the boss gone that day (solidworks+machine time)?
speaking of the lefty, how 'bout a single-sided pivot? that'd be a cool project that folks might buy. still need 2 bearings, but looks like you could make fwd & aft ends single-sided. just an idea.
Expert Crasher
nice work on the machining - it looks fine as is
1 - 18 of 18 Posts
