Got a 404.
I'd take my chances on almost ANY suspension service center vs virtually any LBS. I want someone who does suspension work full time and has seen everything that can go wrong. Few shops have enough work to keep an experienced pro on staff. And even less likely to stock parts.$130 for a fork lower leg service and damper bleed and they don't even pull the air spring.
And it's Jenson, no thanks.
If you can't do that stuff yourself, at least take it to a local shop you trust and can look in the eye.
