Jenson and Competitive Cyclist - End of season blow out
For most of us the season never really ends, we just switch to another style of racing or put on heavier jerseys. For some though, this means getting in new inventory and getting some of the previous season's gear moving. So don't worry about the daylight instead, get some knobber tires for that ride of yours and cruise into the sunset ready to shred the night away. Below are some of the coolest deals we could find in the large SALE sections on Competitive Cyclist and Jenson - Enjoy!
Maxis Aspen EXO/TR Tire - 29in
SALE 20% Off $51.20 $64.00
Minimal rolling resistance, light, and race-ready, the Maxxis Aspen EXO/TR 29in Tire is hungry to gobble up miles of rolling singletrack at top speeds. Affirming that wagon-wheels are the true dominators of cross-cross country, the Aspen packs in low-profile directional lugs in the center tread for rocketing on the straightaways, and aggressive side lugs that keep the confidence high when you barrel into corners. A high-volume casing helps to smooth out rock gardens and jarring root lattices, while EXO protection works to shield you from side punctures. The dual-compound construction means you've got hard, fast-rolling rubber in the center to keep you at top speeds, and extra grip on the sides that keeps you locked into loose berms.
Buy Now
Michelin Wild Grip'r 2 Advanced Tire - Tubeless
SALE 60% Off $26.00 $64.99
When you're hungry for a hefty helping of trails with variable conditions, seating up a tire with dirt-locking grip is an essential item on the menu. With the Michelin Wild Grip'r 2 Advanced Tubeless Tire you'll find just that, with rugged lugs to keep you connected through loose berms, slick mud, and dusty desert classics, plus puncture protection for some peace of mind when you dive down backcountry trails laced with debris.
Buy Now
VITTORIA Corsa G Plus Tire - Clincher
SALE 52% Off $33.05 - $39.95
Anyone with a passing interest in cycling tech has probably been exposed to the hype surrounding Vittoria's new quadruple compound design, the heart of which is a thin, nearly transparent layer of carbon called graphene. The claims made for this material have been impressive, but we weren't sure what to think until we got our hands on Vittoria's Corsa G Plus Clincher Tires. Vittoria blends four rubber compounds with the inclusion of graphene for the Corsa G, and, without throwing any hyperbole around, we'd say the difference is very noticeable.
Buy Now
VITTORIA Morsa G Plus TNT Tire - 29in
SALE 49% Off $35.49 $69.00
Step up and drop in on the Vittoria Morsa G Plus TNT 29in Tire. With an audacious open tread and sharp, squared-off knobs, this tire provides an abundance of grip for any enduro or downhill shred session in a wide range of conditions. The knobs also feature ramped leading edges to reduce rolling resistance when you're doing the work instead of gravity.
The Morsa G Plus incorporates Vittoria's TNT casing, which is compatible with both tubes and sealant-based tubeless systems and reinforced with a Kevlar bead and sidewall protection. This tire also boasts the revolutionary new G+ Isotech compound, utilizing graphene within the compound mix to reduce rolling resistance and overall weight, increase durability, and improve grip in wet weather compared to tires without the G+ Isotech compound.
Buy Now
Fox 32 Float SC Factory 27.5 2019
$495.99 SAVE 45 % MSRP $899.00
Suspension technology has come a long way in the short time that it has been around and it keeps getting better every year. The 2019 Fox 32 Float Step-Cast Factory Fork starts at 2.98 pounds, which makes this the lightest cross-country fork that Fox has ever made. It is optimized for 100mm of travel and has a Step-Cast lower leg design and a narrow crown spacing that saves weight. The Kashima coating of the Factory series makes the fork buttery smooth and incredibly durable. With FIT4, you can adjust your compression damping on the fly. It gives you an open, medium, and firm option so you can adapt to different trail conditions.
Buy Now
Fox Float DPS Turnion Factory 2019
$249.99 SAVE 45 % MSRP $453.00
With a new and improved EVOL air sleeve, Fox's 2019 DPS Factory Rear Shock offers increased responsiveness and sensitivity. The updated valve design delivers improved compression and rebounds flow, and the Factory series comes complete with a Genuine Kashima Coat. With this model, you also get an additional 3 clicks of low-speed compression to fine-tune the Open mode performance.
Buy Now
Shimano XTR Trail Brake
$149.99 SAVE 50 % MSRP $299.99
To provide highly adjustable, high-powered braking performance with no compromise, Shimano designed the XTR Trail M9020 hydraulic disc brakes. The integration of Servo-Wave brake-boosting technology into an XTR M9020 Trail brake generates gobs of lightweight stopping power (125 percent of the previous XTR benchmark, to be exact) that can be precisely rolled on and off with single-finger effort-giving you a better grip on the bar and ultimately better control of your ride.
Buy Now
SRAM RED 22 Rim Brake shifter set
$313.60 SAVE 27 % MSRP $427.00
The SRAM RED 22 ErgoDynamic Shifters continue SRAM's philosophy of perfecting the interface between rider and bike. For SRAM's top-shelf RED 22 series, everything was scrutinized, including the transition between handlebar and hoods, the grip texture, finger wrap, and the separate interfaces with both the shifter and brake lever. The result is an extremely comfortable, highly individual fit that makes the shifters feel like a natural extension of the rider.
Buy Now
Enve M735 32H DT240 Boost wheelset
$1,699.99 SAVE 41 % MSRP $2,900.00
Meet the future of gravity riding and racing, the M735. It is incredibly strong and debuts the most effective and lightest ant-flat system currently on the market (Enve's patent-pending protective rim strip). the rim strip on the M735 offers unprecedented pinch flat resistance and provides you with the ability to run lower pressure to improve traction and rolling resistance. It also provides your precious rim a buffer between it and the trail in case you somehow end up flatting out. Ride without limits or restrictions and go all out as you were born to do. Your confidence in cornering and plowing through rock gardens will certainly get a boost.
Buy Now
Shimano XT Brakeset
$84.99 SAVE 44 % MSRP $153.00
Riding comfortably at white-knuckle speeds requires unconscious, intuitive confidence in your machine. It requires knowing that whatever conditions you come across, your brakes will be ready and able to deliver reliable control in any situation. Say hello to the Shimano XT M8000 Brakes, and say goodbye to compromise. The integration of Servo-Wave brake-boosting technology into XT brakes delivers gobs of lightweight stopping power. Where the M8000 steps up from the already industry-standard BR-M785B is through its upgraded, integrated master cylinder which sports a sleeker look, saves weight and frees up valuable handlebar real estate. It also gains a beautiful black finish that will upgrade the look of any bike. With ceramic pistons to increase power, reduce vibrations and shed performance-sapping heat, when coupled with innovative IceTech aluminum-core rotors (sold separately) to even further keep heat buildup at bay, the Shimano XT BR-M8000 brakes maintain cool, quiet performance under fire.
Buy Now
Enve SES 3.4 Classic Disc wheelset
The ENVE SE3 3.4c disc wheelset is for road cyclists who require maximum versatility for riding in mountainous terrain and variable weather conditions. Since the introduction of the original SES 3.4, ENVE implemented new design concepts across the SES lineup that resulted in a faster wheel and improved the ride experience. The SES 3.4 features 25mm tire optimization and optimized SES aero rim shaping to ensure maximum efficiencies for a shallow aero wheel. Equally, at home in the mountains as in the valleys, the SES 3.4 is the most versatile Smart ENVE System aero wheelset.
Buy Now
