if you can measure from the center of the bolt hole on your hitch out to the point where it clears the spare tire, i can help you with some measurements on the sherpa and others to make sure they will clear without an extension.fishercat said:I have a Yakima hitch rack that my bike hangs on with an adapter. I also hate it. I want a platform rack. I wonder about the 1up rack
I like this as it looks like I might not need an adapter to mount my mojo. can you change the angles of the brackets ?curtboroff said:Swagman makes an excellent spare tire mount that works perfect on my wrangler. Has a very rigid mounting design. Definitely worth a look!
http://www.swagmanbikeracks.com/shopnew/home.php?cat=273
