1 - 4 of 4 Posts
I just started riding a few months ago when I got a stock jamis exhile 29er. The last time I rode I had a small fall and I think it bent the rear derailleur on a rock or tree because when I got back on and started to ride it was working fine for a couple minutes then I was climbing a hill and the rear derailleur snagged the chain and rotated from bottom to top snapping the hanger and leaving the derailleur bent beyond salvage. I figure I might as well do a small upgrade (dont want to spend too much). It is an 8/3 gear set up and I want to keep the shifters.
1. What would be a good/better derailleur set?
2. Do I need a different hanger when upgrading to a different rear derailleur?
With an 8 speed you might be a little limited. What came on the bike?
You can use the same hanger. That said you should replace the hanger. I am guessing when you fell originally you bent the hanger, not the derailleur. Hangers are designed to bend and break off, so you don't damage your as easily.
Vassago Bandersnatch, Motobecane HAL Comp 27.5+, Specialized Stumpjumper FSR 120 26"
Any 9 speed rear Shimano (with Shimano Shifters) or SRAM (with SRAM shifters) will work with an 8 speed shifter and drivetrain. The front derailleur should remain a 8 speed if possible.
You will need a new hanger to replace your snapped one
1 - 4 of 4 Posts
