Hello,
I have not ever purchased a bottle of grease. I do not know much about grease. I have been trying to avoid this mysterious black substance. But, now I need to attach pedals to cranks and I have read that grease is needed for the procedure. I searched around and after scanning through a long thread in this forum about greasing the bottom bracket splines, it became pretty clear the grease is an important component of bikes. So now I want to get an idea of the different brands and types of grease that is recommended for use on the bike. Must i buy bike specific grease (like triflow)... or can i buy grease from the hardware store (like CRC white lithium grease)? Triflow and other bike grease are really expensive compared to grease from home depot. Is this a place where i can save some money, or will white lithium grease not work on bike parts?
Also, what is the difference between grease and oil and chain lube? I am under the impression that oil can be used for chain lubrication (I read some motor oil reviews as chain lube) but not the other way around. I have used white lightning for chains and am switching to rock n roll extreme because of the mtbr choice award. I am guessing that white lightning rock n roll extreme is chain specific lubrication, and i shouldn’t use it in other places.
Also, what is up with wd40? wd40 is a degreaser? i've read that people clean their chains with wd40, but wipe it off before applying a new coat of chain lube. I have used it to stop door squeaks... so is it an oil? Can i spray some wd40 instead of putting grease on the pedals threads...or is that a no-no?
I am sorry if some of my rambling does not make sense...these paragraphs are not very organized... and i tried to type too many thoughts in a short period of time. Well, i would appreciate any thoughts that anyone might have on this subject.
