1 - 20 of 32 Posts
Always pushing harder!!!
Does anybody know in what range will weight be? I'm planning on getting one later this year or early next year and use it for racing. I have a Mach 4 with a mix of X0 and XX, Maguras and Mavic SLR (Cobalts just for regular riding).
Anybody has a similar setup or a fll XX or X0 and share some feedback? Local dealer doesn't have one for me to test ride. I love my Mach 4...will I also love the 429?
I can't comment on the weight, but I was just reading in a Mountain Bike Action mag that the 429 was such a success that they are not yet caught up to the demand for the 429. You will probably have to order one from the dealer and wait for it. Chances are if you love your Mach 4, your going to also love the Mach 429. Same bike but with 29" wheels.
My medium 429 is 27.2 lbs.
Full 2x10 X.0, King/ZTR Arch/Sapim wheels, Talas fork, Thomson Masterpiece, RF Deus handlebars/stem, lunchbox, Specialized SWORKS Captain 2.2 tires (with tubes), Candy 3 pedals.
Paterfamilias
Stock XT M Mach 429 is around 27 or 28 lbs.
Lot's of options to go lighter now, but don't get hung up on the weight. Though it's important, having an efficient bike is far more important.
M429 Xl
Stock XT kit is 30lbs. Very balanced bike. I have changed a few things...
Haven Bar
Haven Alloy wheels
Fox 29 Talas fork
Thomson seat post
WTB saddle
Have not weighed it... :)
I have a small with XX and some carbon bits it weighs about 26lbs. Great bike, can't comment on a Mach 4 but you won't be dissapoionted with the bigger wheels!
dan23 says 27/28 and cphil says 30 lbs for a stock XT build. That is quite a difference in weight. Which one is it?
edit - did not originally see the difference in frame sizes - that will obviously count for some of it.
Dan's is a Med, mine is an XL. The tube set is size specific, so heavier for larger frames.
Oh, I have Shimano M647 pedals on mine. That would make it 1/2 heavier compared to regular XT pedals I think?
Its an awesome bike even at 30lbs. Feels really quick and responsive, not the normal 29er. Great for XC... for me anyway.
Thanks - I did not see your frame size in the title. Makes more sense now.
Yep, and my L XT build came in at 29# without pedals. So all those numbers sound about right!
Discussion Starter · #16 · (Edited)
My guess is if I go for a 429 is that it would be a size M since TT is as long as a L in the Mach 4...I'm considering building the bike...$$$ and weight will be big factor...Still this is my end-of-year project for next season...
Thanks for the input...
Mine is a size small with a tapered steerer Fox 15Q with XX and I-9's. It's in tank mode right now with some 2.25 Ardents mounted for winter riding, but with IKON's on it's at a race weight of 25 lbs. AWESOME rig, I love it.
Stock 2010.5 (Talas fork, 3x10) XT build, size large + XTR pedals + rim tape + 2 scoops of Stan's each + 2Bliss Captain Controls (2.2, 2.0). 29.5 lbs. changed to Easton Havens and tubeless (same tires) + 2 scoops Stan's each. 29 lbs. Park scale rounds to nearest .5, so these weights could be off a few tenths just from rounding.
I changed to Haven's for the UST aspect since I didn't like dealing with rim tape.
WheelDancer
I'm also looking at getting a 429 but am not sure about sizing. The large has the same TT and stand-over as my hardtail (Fisher, Paragon 29er) but I'm hearing you should size down for the Pivot.
Any insight would be welcome!
I have a large ( 19) 2009 Paragon it has a 105mm stem stock and is the same as my Medium PIVOT 429 with a 80mm stem. I have a longish torso and shortish arms and the fit of both is perfect
1 - 20 of 32 Posts
