that's a lttle inconvenient. i'm kinda happy with my 160mmcrisillo said:yes, but you will need to increase your rotor size a bit, if you are running a 160mm rotor...
for that case shimano makes a 170mm and 203mm IS-to-PM adapter and rotor
170mm adapter: http://www.chainreactioncycles.com/Models.aspx?ModelID=13744
203mm adapter: http://www.chainreactioncycles.com/Models.aspx?ModelID=13748
170 and 203mm rotors: http://www.chainreactioncycles.com/Models.aspx?ModelID=756
I hope this helps,
Cris
the only way around it is buying a postmount caliper then.... (170 is a minimal increase, but still a bit more weight)mpap89 said:that's a lttle inconvenient. i'm kinda happy with my 160mm
michael
