Hey there, I'm upgrading my drivetrain (BB, Cranks, rings, cassette, chain) and wondered what are the pros/cons of square taper VS ISIS providing BB is the same as the cranks??
How are you going to use a King bb with an ISIS or square taper crank?doctorbangbang said:The isis middleburn set up is also a bit lighter. I'm no weight weenie but thats a good enough reason to use ISIS again! I've also never had any issues with my previous splined system. Thanks for the feedback guys! So the plan is... Chris King BB with Middleburn triple chain ring and cranks.
The ISIS Middleburn cranks are about 25 g lighter than square taper, but the ISIS Ti BB's are about 50g heavier than a light square taper (like Phil Wood), so the ISIS crank+BB is about 25g heavier. I just got a ISIS Middleburn crank and FSA BB and I'm going to return for a square taper. Added advantage of Phil Wood is you can adjust the chainline by up to 5mm.doctorbangbang said:The isis middleburn set up is also a bit lighter. I'm no weight weenie but thats a good enough reason to use ISIS again! I've also never had any issues with my previous splined system. Thanks for the feedback guys! So the plan is... Chris King BB with Middleburn triple chain ring and cranks.
Might also rethink your assumptions about weight. Total weight of an external type bb crank is comparable to that Middleburn plus ISIS bb.doctorbangbang said:Yeah, the CK BB and middleburn cranks won't go together will they! I might rethink the BB choice...
Where did you buy the crankset?MadDuc916 said:Doctor BB,
I just finished a bike build and after a lot of research, I went with the American Classic Ti BB and the Middleburn 2 x 9 R8 crankset. Previous to this I had run the American Classic Ti BB for close to 10 years with no failure. In talking with my LBS, they did say that the external BB required at least a rebuild every year. I am close to 240 with gear on and I have never bent a a square taper ti Spindle FWIW. This set up is pretty much bomb proof and is very light. I am very pleased with the Middleburn cranks as are most people that have posted on the forum that I have seen. Here is a picture of my current 2 x 9 Middleburn/American Classic set up. If you have anmy questions, let me know, I am happy to help with any details.
Hoipe this helps.
