What bottom bracket you got?micky said:I want to replace a crank on one of my bikes. I already have a new isis bottom bracket but not the crank. Should I get a isis crank (they seem reasonable and around or under 100.00 or I have seen lx outboard bearing cranks for 121.00
I personally have not had a problem after upgrading to RaceFace Deus. I use the middle ring 90% of the time and use my big cogs quite oftten. I have a sugar.micky said:I am somewhat concerned about the chainline. I generally use the 3 or 4 largest cogs when I am in the middle ring. Will this be a problem. This could be a large cossover if the chain line is moved farther away.
