Hi: I've had terrible luck with the external bearings for the Race Face crank on a bike I built up 2 years ago; replaced the bearings more often than I've replaced the chain! Even tho' the crank/BB set is from, you know, British Columbia, it apparently doesn't like the Pacific NW wet season (which can be well over 6 months of the year). Building a "winter" 29er hardtail, would like to just avoid this problem. Looking at ISIS bb's and cranks on eBay. It looks like there are some older ISIS cranks out there, and with an AM Classic BB the weight would be close to a modern external bearing setup. But the ISIS (or Octalink, if such are comparable) bearings are smaller than either old-school square taper or ext. bearings.
What would you all recommend for this type of riding: slow 200-lb rider, XC trail only, no air but lots of logs and rocks to ram with a bash ring?
