Anyone had problems removing their ISIS crank arms? Mine came loose a few times on the trail after being torqued to spec, so I greased the splines again & went up another 7ft/lbs. Arms didn't come loose again, but now after 6 months of no problems, I broke my crank tool (yep, I did use the large ISIS/Octalink botton) & tore the theads out of the crank arm trying to get them off. This was the non-drive side Truvativ Firex Team crank.
Did I miss the part about greasing the puller tool threads before using them? Should I expect the same from my Stylos?
