ISCG standard....
primarily has to do with chain guides and the configuration of the mount. The Reign is not designed to use a chain guide and therefore does not have ISCG mounts. If it did they would be situated around the bottom bracket housing on the drive side behind small ring of the crank. A bash guard simply replaces the big ring on the crank set. The two things you'll need to consider are the bolt circle diameter (BCD) of the crank and the bash guard, the two must match, and the number of bolt holes that the crank and guard have. Those also must match. If the BCD and number of bolt holes of the bash guards match your crank I'd bet that either would work. Not a bad idea though to have them both on hand to see which fits best.
Good Dirt
Good Dirt
