So, I other words, you want the tension variation to be within 5%?Too much variance on the drive side for my liking. I'd try to ev n them out more so the max is 120 and minimum is around 110. This assuming the max recommend tension for the rim you're working with is 120 kgf and that the rim is in good condition.
Good call -- assuming he survives.go for a ride/spin then come back and retension
I am using cx-ray spokes
Well I am not sure where to start, but I will use tension meter to get all spokes the same tension (13.5 for high tension side, 7 for low tension side), then I will see how the wheel spins and try to true it from there. Not sure if thats the correct way but I will try it
Is there good method to relieve stress during the build process?How are you stress relieving the build? Doing that as you tension and true is totally a necessary part of the build.
"Stress relieving to relax these high stress points is accomplished by over-stressing them in order to erase their memory. It is not done to bed the spokes into the hub, as is often stated. Bedding-in occurs sufficiently from tension. However, stretching spoke pairs with a strong grasp at mid-span, can momentarily increased tension by 50% to 100%. Because spokes are usually tensioned no higher than 1/3 their yield stress, this operation has no effect on the spoke as a whole, affecting only the small high stress zones where spokes are near yield. By stretching them, these zones relax below yield by as much as the overload.Is there good method to relieve stress during the build process?
If not done during the wheel process, can it be done after the fact. Ie, ride for a few miles and re-tension?
FWIW I use a wood dowel and twist each pair of spokes together with steady force then release. Then I recheck true and see where I'm at. It has worked well for me thus far - my builds have stayed true and tight.Is there good method to relieve stress during the build process?
Looks better. What are you trying to correct for on spoke 2? It looks like you are trying to pull it into true, but how close? Whether using the cheapest or most expensive components, the building technique is the same, it just may be you need to allow a bit more runout to get more even tensions.Ok the truth is I am using chinese hubs (ztto R2 road hubs) and chinese carbon rims (25mm width 50mm deep 24 hole), also using chinese CN-MAC 424 Aero Spokes (same specs as cx-ray), I didn't want to mention that because I think true wheel builders hate to hear it lol but since its my first wheel build I decided to go cheap.
I am using a bladed spoke holder as I turn the nipples, i am pretty sure there is little to no wind up and there is no stress to relieve but I still am doing the methods I find online to relieve the stress but after I do it I notice no difference in how the wheel spins.
I am noticing its the spokes near the valve hole that seem to need more tightening on one side, I will just assume since these are cheaper price rims they do not have the top quality and I guess I need to add a tad bit more tension in that area.
I just finished up building the wheel again and it turns out better this time, I probably did not need to do all this work I should have just loosened the spokes that were too tight and went from there but honestly I still need more practice building wheels since this is honestly my first one and I am happy with the results to be honest, here is the new tension graph
Just trying to be a good commie.This is one of the best posts I have ever read on this progressive socialist website.
